Results 11 to 14 of 14
    Sep 2013
    12
    OK, so today we did nothing but MIG :shock:
    Started laying down some beads to learn the settings of the machine. Here I started at the bottom, and then went up as I made adjustments:
    After a few beads, I then tried this weld on the butt joint line - right in the middle of this picture:
    Sep 2013
    12
    After this I started doing horizontal butt joints. Not quite "hot" enough:
    Sep 2013
    12
    Once I adjusted the heat, I was getting a little bit better welds (still needs TONS more practice!):
    I then practice doing this outside corner joint, vertical (going down):
    Sep 2013
    12
    And finally tried multi-pass inside corner joint vertical, laying down a root pass and then overlapping passes. The middle is still concave instead of flat, so next time I need to build up the middle a little bit more:
    Will
