Results 11 to 14 of 14
    732
    Hey Bob,
    "Looks great Bob. How does the strength compare to the parent metal?
    Thanks,
    Nick"
    3,950
    Quote Originally Posted by kiwi View Post
    Hey Bob,
    Thanks,
    Nick"
    I have done other projects for myself with that wire and the strength is real good, but the projects have been small. Big stuff i still use rod on...Bob
    Jul 2006
    alaska
    182
    Default Cast
    Cast is a nightmare for me. I weld it with the highest nickle you can find,,,, crack. Some times it doesn't even looks cracked, but when I dye penetrate it, I find all kinds of little hairline cracks. I usually tell people "I weld cast no guarantees though" especially if there is a lot of force on it. I thought one time I was winning on an old crank for a generator, heat up, slow cool in oven, Ni rod 55,,,,,Crack! I told the guy it would just be easier to make a new part which I did.
    Cave Creek Az
    1,051
    low nickel is Ni55, and I'd Not machinable, as there is still way too much carbon. The high nickel is Ni99 and is machinable.
