Results 1 to 10 of 14
    3,954
    Cool Antique cast iron clamp part fixed
    A guy at work dropped this part off and asked if i could weld it. Yup no problem i said. Fired up the MM185 with crown alloys .035 cast wire and 75/25 gas and tacked it together. Ran some beads and cleaned it up...Bob
    Sep 2008
    Dalton, GA
    131
    Good job, Bob.
    Looks like he should be happy with that. I'm curious how you are able to mig it when everyone says it has to be heated and cooled slowly etc. ? Was it just this part and the way it was broken or will that work on other cast iron?
    Burt
    _______________________
    Miller 211AS
    Miller 375
    Miller Syncrowave 250
    Miller Thunderbolt XL
    http://www.10FtDrillBit.com
    Lodi, CA
    1,313
    Bob, you've mentioned this wire before. I just looked up Crown Alloys, seems everything they offer is nickel-based. Exactly which product are you using? I do enough cast myself it is worth picking some up, I normally use nickel rod but I think the lower total heat input from wire (vs 1/8" stick) would minimize cracking problems afterwards in many cases.
    Thanks in advance,
    Joe
    Cave Creek Az
    1,066
    It is the Crown Alloys. royal 44-30
    Lodi, CA
    1,313
    Thanks.
    What percent nickel is this? The website doesn't give a whole lot of information. I even downloaded the tech sheet, nothing.
    I'm guessing the best place to order from is Indiana Oxygen.
    To the earlier poster wondering why this works w/o preheat and postheat, you can use the same amps with wire, but reduce the total heat put into the work you would be applying with stick.
    3,954
    Thanks.
    I have the Crown Alloys catalog and it doesn't have the nickel content either. I think Indiana Ox had the best online price. I paid 75 bucks local...Bob
    Lodi, CA
    1,313
    Thanks, Bob.
    Turns out there was nobody local to me that carries Crown Alloy 44-30, or even had any interest in ordering it for me, ended up buying from Baker's Gas, the only online source I could find that was point, click, and pay. Ended up using it this weekend, on a couple stove doors. Almost impossible to preheat them without sticking the whole thing in an oven. Stick weld with nickel, it cracks somewhere else. Try brazing, it cracks somewhere else. With this wire, I was able to weld it one inch at a time (in the correct progression and direction), letting everything cool in between welds (I had other things to do in the meantime), no cracks.
    3,954
    Good to hear...Bob
    735
    Looks great Bob. How does the strength compare to the parent metal?
    Thanks,
    Jun 2009
    greenfield new hampshire
    889
    when ya go to buy stick cast rod, there basically 2 choices, low nichol content,w hich is machineable and the higher nichol content which is not machineable, mayby in the wording on the label will shed some light, the low nichol is less than 50 %
