Results 1 to 4 of 4
    Default dialarc hf & 8vs suitcase
    Can my suitcase be used with dialarc? What settings? Help!
    Jan 2012
    Coos Bay Oregon
    22
    Add Content
    Beenweldingawhile please repost your comment. ..thanks
    Jun 2009
    Appleton, WI
    47
    Not really the best combination of items, but you can pull it off if you will be welding in a spray transfer of solid wire or with a flux cored wire. You will not be able to do a short circuit transfer solid wire because the volt/amp curve response of the Dialarc will drop very quickly and the feeder will want to shut off.
