    Sep 2013
    3
    Default New to forum and have a ?
    My first post and I have a question about my mig. My XR wire feeder with a Python Aluma-pro gun will work normally until I release the trigger. The gas will keep flowing until I hit the jog/purge switch. Is it the gun or the feeder?
    Thanks, Randy
    8,179
    some have a bult in post flow setting,a serial # would be handy
    Sep 2013
    3
    Quote Originally Posted by Clyde View Post
    Thanks, Randy
    Serial # lg141314w
    8,179
    OK, remove the right side cover, inside you'll see a control board and a red 2 pin dip switch, The first one is for a 0.5 second preflow, the second one is for a 3.5 second post flow. If you don't want any post flow merely turn that switch down to off. There is no time adjustment, either you want it or you don't.
    Sep 2013
    3
    My bad, machine has been working properly for a couple of years now, just recently started this problem. No switches have been moved. Was told it might be trigger switch,bought one from local distributor and was wrong one. I have all the manuals but they have been no help so far. Thanks Randy
