Results 1 to 10 of 12
Hybrid View
    Oct 2011
    24
    Default First time spool gun user! Help
    Hi guys, I have a millermatic 185
    and a friend gave me a used 30a spool gun!
    I'm not much of a steel welder but been wanting to learn aluminum.
    now the issue when trying to use it I can get a weld that looks ok for the first time
    but every other try starts with a spark and wire balled up in the gun?
    I can't tell that I am doing anything different?
    but it is most of the time. The wire speed is controlled on the machine not the gun
    because of the type machine. Any idea what to look for? Thanks
    Oct 2004
    Edmonton, Alberta
    8,104
    Huh, you can't plug a 30a gun onto a 185 for one thing, maybe tells us what machine you really have?
    Apr 2013
    metro Detroit
    91
    It does look like you can not add a spool gun to the mm185. You can the mm180 though
    Nov 2003
    3,429
    Quote Originally Posted by bigtow30t View Post
    The hookup chart mentions a "Spoolmate 185"
    http://www.millerwelds.com/products/...gun-chart.html
    Might have to do some adapting to make that 30A hook up...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Oct 2011
    24
    Guys, Sorry. I bought a switch kit and a adapter cable that lets me hook up with a switch inside Anyway it won't use the spool gun wire feed control
    but have to just use the machine wire control
    Nov 2003
    3,429
    Question
    Quote Originally Posted by fishbum View Post
    "switch kit and a adapter cable"
    Could you give us more details, supplier?, model?
    installation and op instructions?
    pics?
    My Blue Stuff:
    Millermatic 200
    Oct 2007
    Cave Creek Az
    1,040
    My MM185 has the adapter switch and has hose tee on it. Power cable just bolts on inside the machine. It is supposed to use the 3035 gun not the 30A.
    Oct 2004
    Edmonton, Alberta
    8,104
    Pretty tough to hookup the 30A to the 185, even so, 030 AL wire and straight Argon is what your after
    Salem ,Ohio
    3,936
    Cool
    Really. I have been using my MM185 with a 3035/Spool Mate 185 since '99...Bob
    Apr 2013
    metro Detroit
    91
    Sorry I did not complete my thoughts, I was thinking that it was not a plug and play.
    My mm211 is set up for it from the start. I did not see anything about it in the manual for the mm185 I found at a friends shop.
