    Dec 2012
    7
    Default Can you spot weld a plug weld?
    For the autobody repairs that I'm doing, I'm using a lot of plug welds. Obviously, these don't have the same appearance as the factory spot welds. I recently picked up a used miller spot welder and was wondering if I could go back and use the spot welder over the plug weld. I've tested it on pieces and it looks OK and seems strong enough. Intuitively, it seems like it should be OK. I'm just an amateur, so I thought I would get opinions from people with more experience. My real concern is does it weaken the original plug weld? Is there any downside to doing this? Any other thoughts?
    Aug 2008
    Orange, TX
    1,215
    Unless I'm missing something, why do you feel the need to go over the plug weld(s) with a spot weld?
    On automotive sheet metal, a properly done plug weld is only slightly more detectable than a typical spot weld and will hold just as good.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2012
    7
    Strickly for appearance. After grinding the plug weld it pretty much disappears. In certain places, I would like it to look like the factory spot weld.
    Nov 2003
    3,324
    Quote Originally Posted by rick66pony View Post
    why not put your "cosmetic" spotwelds on either side of your plugwelds??..
    would probably give you a more authentic looking "dimple"... if that is the effect you are trying for in a Mustang?... restoration... just a guess from your Sig...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
