Results 1 to 10 of 10
    Sep 2013
    5
    Default mm 350P WITH HELP CODE 3
    changed gun out , still has help code 3 when powered up
    Nov 2003
    3,629
    Question
    This is what the manual has to say..
    Help 3
    Indicates gun trigger was pulled and held
    during power up. Release gun trigger and
    clear fault condition. Also, this display can
    Indicate no open circuit voltage detected
    when gun trigger is pulled and no arc
    detected within 3 seconds. Turn off primary
    input power and contact a Factory
    Authorized Service Agent
    http://www.millerwelds.com/om/o1327ah_mil.pdf
    Page 49
    Have found over the years that the help codes may indicate a condition or conditions totally different than what the manual says... many times something simple like a reset to factory defaults may clear the errors..
    sometimes conflicting program commands will confuse it and throw out odd error codes...
    Cruzer or one of the Miller factory Techs probably have some ideas..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jan 2012
    Appleton, Wisconsin U.S.A.
    147
    Try disconnecting the gun trigger lead from the machine and turn on the power. If the problem remains you will need to take it into a service station. If the problem goes away then you have had some bad guns.
    Let us know how it turns out!
    Thanks,
    Miller Welding Forum Administrator
    8,281
    Quote Originally Posted by STEELREELIN View Post
    disconnect your spoolgun as well, if its there, I find that when powering up (no pressing the trigger) that 99.9% of the time its a stuck or shorted trigger.
    If you hit the trigger and that error turns on, then yes you have a internal problem.
    Sep 2013
    5
    thanks, blowed out machine, wiped off some metal filings on the top board and code 3 went away. welded with machine everything seems good.
    Nov 2003
    3,629
    Thumbs up
    Glad you got it sorted out...
    Makes a good case for Vac & Blowing them out at least once a year...
    the MM350P is just such a great MIG machine...
    My Blue Stuff:
    8,281
    I'm glad you got it sorted out as well. buttt there isn't any top board (Horizontal), and it would be near impossible to get a filling into any of the boards inside the unit, unless it was running without the covers installed. So what really was the problem.
    Sep 2013
    5
    Thanks, the horizontal control board was really covered with dust, and pushed connectors up tight,had tried many times before that, to get it to come on, we fabricate and do alot of grinding.
    8,281
    Again, no horizontal boards in these. They are all vertical. Dust doesn't affect them anyways. So a coinsidence maybe
    Sep 2013
    5
    [QUOTE=cruizer;311440]Again, no horizontal boards in these. They are all vertical. Dust doesn't affect them anyways. So a coinsidence maybe[/QUO
    control board is rectangle and runs horizontal right behind the control knobs, metal filing can enter these machines really easy this machine was about 7 years old , yes, there was alot of metal dust on the horizontal soldered board.
