Hey guys, I'm setting up to run some .035 flux-core through a 350p for an outdoor project. In the set-up menu their is no option for flux-core, just stl, ss, alum, and mcore(metal core). I swapped leads to DCEN and selected stl(steel) in the set-up menu. Ran a couple beads on some 1/4 inch at 16 volts and around 240-250 ipm. Seemed to me like everything ran fine. Is this method ok? Wasn't sure if I needed to run metal core in the menu, even though your only option for wire size in that selection is .045. Thanks in advance for any info and experience with this situation. Ja
