Results 1 to 3 of 3
    Aug 2013
    100
    Default maxstar 200dx parts?
    where can I get the gas receiver fitting that goes into the face of the machine as well as the clip to hold it in and the hose to connect to the solenoid? Thanks. Dave
    Nov 2003
    3,733
    Thumbs up
    Quote Originally Posted by JerseyWelder View Post
    If it were me....
    I would probably look them up in the parts manual...
    then order them from Miller4Less....
    Parts manual Maxstar 200 Series
    http://www.millerwelds.com/om/t2226u_pt_mil.pdf
    Figure 11-3. Panel, Rear w/Components (Figure 11-1 Item 2) Page 124
    5 . . . . . . . . . . . . . . . . . . 193649 . . . . Ftg, Gas Barbed 1/4 TBG 5/8−18 Female . . . .. . . . . . 1
    Try Miller4Less $16.41
    http://miller4less.com/product_info....ducts_id=35769
    And the clip…
    601 . . . . . . . . . . . . . . . . 166560 . . . . Ring, Rtng Ext .500 Shaft X .042 Thk E Style Bowed . . . . . .
    $2.16
    http://miller4less.com/product_info....ducts_id=30996
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Aug 2008
    Orange, TX
    1,223
    Jersey - Although miller4less is the go to place for most, be advised they have a $10 shipping adder for orders under $100 and a small order charge of $7.95 for orders under $30 so factor that in as well. You can avoid one or both if you order other needed items at the same time to get the total up.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
