Results 1 to 10 of 11
    Aug 2013
    12
    Default Factory modification to a Syncrowave 250, troubleshooting help?
    I have a 1989 Syncrowave and the current adjustment knob is "compressed" so that 0 amps starts at a about 70 A dial setting. It uses the older type PC1 board. The high end is OK so that I get 300 A at the max setting. Adjusting the pots that set max and min current will not trim this out.
    It looks like the op-amp that measures the shunt had some components replaced around it with a tacked on capacitor and spade lug to ground. Someone added a third wire to the shunt also. Does anyone know if this could have been a factory mod that isn't documented? --Not sure why anyone would do this. The foot pedal in remote works fine also (0 current to max current fully depressed, no matter the dial setting).
    Any help would be appreciated. Thanks.
    Nov 2003
    3,417
    Sounds like somebody may have accidentally installed an "Audio Taper" potentiometer during a repair... rather than the linear taper it requires ...
    just a guess...
    Cruizer may have a better answer...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Aug 2008
    Orange, TX
    1,215
    X2 on H80N's audio pot theory.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Northern California
    205
    Quote Originally Posted by duaneb55 View Post
    I agree. If that is the cause, the potentiometer could be replaced with the correct linear taper potentiometer. It's likely that the original potentiometer went bad and was replaced with the wrong style. After all, a potentiometer is a potentiometer, isn't it? Not it's not.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
    Aug 2013
    12
    Thanks everyone, I measured the voltage on the pot wiper and it is linear from zero to the max setting. But when I plotted the current output as a function of the pot position, its like the first 1/3 turn does nothing. Also, the relay, CR1, doesn't actuate at all until I get past the 1/3 turn.
    Nov 2003
    3,417
    Still betting that somebody erroneously installed an audio taper (logarithmic) pot during a repair... rather than the needed linear taper..
    Easy enough to find out....
    the potentiometer should be marked...
    My Blue Stuff:
    Northern California
    205
    Quote Originally Posted by engrx2 View Post
    Voltage tests won't tell much if the potentiometer is still in the circuit. What is important is the resistance of the pot. when disconnected from the circuit.
    If the first third of the pot's movement does little or nothing, then it is by definition non-linear, i.e., Audio taper. This is further shown by your statement that the relay doesn't move until past the first 1/3 turn. This proves that the resistance is greater in that position than a similar linear pot. would be.
    I'm betting with those who say that the wrong pot. was installed. I would remove the pot and test it for resistance and, if non-linear, replace it with a liner pot of the correct wattage.
    Milermatic 252
    Aug 2013
    12
    Well I tried it with the Miller foot pedal and I get the same effect: No current for the first 1/3rd of the pedal, then the current picks up gradually to full current at the bottom of the pedal. So I think something in PC1 is flaky. And I cannot adjust it out with the on board trip pots.
    8,094
    Well if the local control pot is not correct then your remote will be wonky as well, cause they work in tandem. Geez change the thing. Looking for a 1 K ohm 2 watt pot. Any electronics store will have it. Might cost 6 bucks
    8,094
    Either the wrong type of potentiometer or the wrong resistance.
