Results 1 to 10 of 10
    Aug 2013
    12
    Default 1989 PC1 Syncrowave 250 Schematic
    Does anyone know where I can get an original PC1 schematic (D-122 270), parts list, and an original service manual? The one Miller provided by email is low resolution and it is tough to make out the part designations. Thanks
    8,003
    Email address and serial#
    Aug 2013
    12
    Thanks, my serial number is JJ468041. The tech manual for this unit is OM-353 Rev 0 (The one on line is OM-353 Rev E and doesn't have the older D-122 270 schematic).
    Aug 2008
    Orange, TX
    1,215
    Manuals with the OM prefix are "Owners" manuals and not tech manuals that have the prefix TM.
    Here's your correct unit manual http://www.millerwelds.com/om/o353a_mil.pdf that has the referenced D-122-270 drawing on page 25.
    Still may not be clear enough to read and the correct technical manual TM-353E has it referenced but not included.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    8,003
    Quote Originally Posted by engrx2 View Post
    I have the TM manual, but you neglected to give me your email address
    Aug 2013
    12
    Thanks cruizer, I actually sent you an email. I'm new here. Did that work?
    8,003
    nope. my address is : ventureline@shaw.ca
    Aug 2013
    12
    Cruizer, just replied to your email address. Thanks.
    Aug 2013
    12
    Cruizer. Thanks for the manual. Unfortunately the schematic for the old PC1 (D-122 270) isn't in this latter TM-353 Rev E manual. I think I need a TM-353 (Rev 0 or Rev A).
    8,003
    Maybe, but your not going to find it unless its on a Owners manual, cause I have acces to ALL the exsisting tech manuals,
