Results 11 to 13 of 13
    Aug 2013
    Pennsylvania
    6
    Too late, I just bought the 100A service cable and 100A breaker this morning. It is aluminum though. The clerk said it's #3 wire. I am running the service cable to a box by the welder. The welder is only about 8 feet from the main box. There is a 6 foot piece of BX cable, with copper conductors hard wired to the welder by the previous owner. They look like #4 wire. That will be connected to the service cable at the junction box. I guess that will be OK. I know the electrons don't know the difference, but I am a little curious about the color code on the wires on this service cable.
    I have the bare ground, red w/ 3 white stripes, black w/ 3 white stripes and a solid black wire. I think the black w/ 3 white stripes, or is it white w/ 3 black stripes, is to be the neutral.
    I found steel 3" castors at the local TSC. They are rated for 300 lbs each. Should work for a 830 lb machine. At least I will be able to move the machine around on the concrete floor by myself, for maintenance if needed.
    Oct 2011
    Minnesota
    54
    Quote Originally Posted by GBertolet View Post
    ...It (service cable) is aluminum though.... There is a 6 foot piece of BX cable, with copper conductors hard wired to the welder by the previous owner. They look like #4 wire. That will be connected to the service cable at the junction box. I guess that will be OK. I know the electrons don't know the difference....
    You need to use the proper terminals and preparation for terminating aluminum wire. If not, expect a fire. Maybe not right away, but eventually. That is probably why you were advised to stay away from Aluminum.
    If I understand correctly, you are going to splice the copper to the aluminum. This can be done, put has to be done properly.
    Nov 2003
    3,423
    For me....
    I would spend the extra and get copper...
    aluminum wiring scares the bejeebers out of me....
    it may be just fine.... but I would worry over it enough that it would be worth my while to invest in the copper.. just for the sake of peace of mind..
    and I know it is all to easy for others to spend your hard earned dollars...
    just my 2cents worth..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
