Results 11 to 15 of 15
    Oct 2011
    Chandler, AZ
    11
    Quote Originally Posted by tackit View Post
    I'm trying DraftSight but I can't find out how to erase, copy or even select?
    Select by left-clicking on the line/rectangle/circle/etc you want to manipulate.
    Copy by selecting and then type "copy" in the command window, select base point and destination point.
    Erase by selecting item, then pressing delete.
    Oct 2005
    North Central Indiana
    782
    I need to do the tutorial I tried deleting using the delete button and using erase but nothing is removed from the screen.
    Thanks guys for your help, I appreciate it.
    Oct 2005
    782
    I was ale to learn the basics of DraftSight , nothing is drawn to proportion but at least I got this far.
    It's a bench press I going to build out of 30" 6" 25# wide flange I beam, 3/8 side plates for reinforcement, 2 3/8 round stock for the port a power's stand offs, 7" heavy channel Iron for feet and supporting a 1" press plate and my 10 ton port a power..
    I have a 1" X 6" plate bored and threaded for the 10 ton cylinder, just need to cut it to the right size.
    http://i1298.photobucket.com/albums/...ps8d95caa3.png
    http://i1298.photobucket.com/albums/...ps4dd62793.jpg
    Below is the KNUTH bench press I got the idea from.
    http://i1298.photobucket.com/albums/...ps1a9732a2.jpg
    http://i1298.photobucket.com/albums/...ps610e63b2.jpg
    Feb 2013
    Kansas City, Missouri
    11
    I use CAD Standard (CADSTD) standard free, Pro $25 AutoCad feel
    Oct 2005
    782
    Ill give it try to thanks ChuckS
