Results 1 to 10 of 15
    Oct 2005
    North Central Indiana
    782
    Default anyone use a free CAD program
    I would like to draw my next project on the computer but most programs have a learning curve that's to long for me..... is there any easy to learn free programs out there? thanks
    Nov 2012
    Northern Arizona
    537
    Sketchup is free and pretty easy to learn. That is the only free one I have used.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Oct 2005
    782
    Thanks elvis, I'll give it try.
    Oct 2012
    4
    If you only need 2D, Siemens Solid Edge2D is very good. Free and comes with a useful tutorial to get you started.
    Sep 2012
    Coastal Maine, Coastal NC
    25
    I've been using DraftSight for a couple of years now. It's available for PC and Mac and a couple other operating systems. It's fully AutoCAD compatible and has the same instruction set...at least so far as I can tell. There are a couple of tutorials for it to get you started.
    It is free but you have to register your copy. It's a very nice product.
    Oct 2005
    782
    Nice of you all to help me, thanks guys, I'll give them all a try.
    Oct 2011
    Chandler, AZ
    11
    I second DraftSight. Good program especially since it's free. $2,500+ for AutoCAD is just absurd unless you're doing 3D all the time.
    Apr 2011
    365
    Default Sorry but...
    Quote Originally Posted by ILikeFlyin View Post
    If you're doing 3D all the time you aren't using AutoCAD... you are using Inventor or the likes of it.
    AutoCAD is mostly a 2D drafting program.
    Just For Home Projects.
    Oct 2005
    782
    I'm trying DraftSight but I can't find out how to erase, copy or even select?
    Sep 2012
    25
    If you're having that level of trouble with DraftSight, then I'd have to conclude that you have not done the tutorial. Go ahead....do the tutorial. It's kinda fun and will get you used to most of the commands and procedures. You can operate DraftSight from the command line using AutoCAD commands but it's a lot more fun to use the graphical tools and mouse.
    If you're operating on a Mac platform, you should be aware that the tutorial was written for the PC version so some of the display screens, particularly some of the preferences, won't be quite the same. It's a pretty small matter but it did cause me some head scratching when I went to work on my iMac.
    BTW "select" is via single mouse click on the object or by a window drawn by dragging the mouse to describe a box around the desired objects. Delete is via the Delete key or by means of the little eraser in the "modify" toolbar.
