Results 1 to 3 of 3
    Aug 2013
    1
    Default Water cooler for Airco Heli Welder
    Hello all, I recently was given an old Airco Heli Welder, mdl. 2A/DDR-224HPA/B-D. I am trying to build a water cooler on a budget. I bought a pond pump (158gph) from harbor freight. This pump does not move water thru the torch, (barely a trickle). I checked all the lines thru the torch and the solenoid valve and are open. Do I need a pump that will produce a high pressure to push the water thru the torch hoses. I was hoping that the pump I bought would push the water thru since it is basically a open system. Thanks
    Nov 2003
    3,336
    Thumbs up
    Quote Originally Posted by 609thomasm View Post
    you need to look for a Procon vane pump set for 60 psi @ around 2 gallons per minute..
    here is a thread on SFT that should answer your questions..
    including some of the gotchas..
    http://shopfloortalk.com/forums/showthread.php?t=39374
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Aug 2007
    Northern California
    200
    Yes, a Procon is the pump of choice for a water cooler on a welder. I have a couple of them and they take a lickin' and keep on tickin'.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
