Results 11 to 14 of 14
    PA
    350
    ByerlyJ,
    A few questions to help with some ideas,
    1 - What processes has your course covered?
    stick, mig, tig, oxy-fuel (cutting, hard soldering, brazing) , plasma, submerged arc,
    2 - What do you believe your instructor wants to see?
    and does your project need to showcase all of these processes.
    2a - Even smooth welds, good fit-up - (craftmanship)?
    2b - Clever design ideas or new concepts.? (Easier said than done - Apple is a good example)
    I'm no help here otherwise I'd be rich.
    2c - Does your instructor have a particuar interest? (trains, planes, automobiles)
    (ok - may be a bit of apple polishing here)
    Materials used in your project?
    You mentioned nothing big or expensive.
    I don't know what process you have available for your project but - here are a few ideas -
    (Tig) - Stainless steel - use common silverware - cheap at thrift stores.
    Pots, pans, spoons knives, forks.
    Show how you can run small, even tight welds without burn thru or sugaring.
    (Tig, stick, mig) - project better suited for thicker material here.
    Make a name plate or sign using weld bead like the wood names routed out of wood.
    Combine processes - plasma cut several different designs into a few plates and weld into a fire pit having 4, 5 6 or more sides.
    (If plate is too expensive, buy a small Weber bowl type bbq and cut designs into the lid.)
    Make sure it is painted steel and not porcelainized for oxy-fuel cutting.
    Good luck
    Sep 2009
    South Carolina
    570
    Quote Originally Posted by Burnt hands View Post
    ByerlyJ,
    Good luck
    Now I like that kind of stuff. I would love a rubic cube done up like your dice. Got me to thinking. Here is why,
    THis is me
    https://www.youtube.com/watch?v=O7vIhRA9nVw
    The spoons were cool also. everything was, thanks
    Nov 2005
    106
    Default project
    make a couple beer or coke can holders for when you are b b queing
    google it I make mine out of 5/8" round and horse shoes or hand cut texas cut outs to hold bottles sold a few and gave out a few
    Mar 2014
    Default horse shoe welder
    Try this out, horseshoes are cheap and very easy to weld.
Tags for this Thread
