Results 1 to 2 of 2
    Oct 2012
    4
    Default miller 22p12 problems
    Hi, I've suddenly got a problem with my wire feeder.
    It's dead...or if I press JOG switch it starts to feed.
    But nothing hasppens if I press the pistol trigger.
    I have connected it up to 2 different Miller xmt 350, even got 2 22p12 wire feeders, and none of them are working.
    It's been sitting in my garage for half a year, but both worked when I placed them there.
    Is there something I could easily check/measure?
    Regards
    Panasync
    Oct 2012
    4
    Found the problem, bad connection on the printcard inside wire feeder.
    So now it's working fine
