Results 1 to 3 of 3
    Default miller 130xp not working correctly
    when I pull the trigger it welds for a second then stops I check the main relay it seems to be working properly the problem I'm having is the main contactor click in and then clicks out if I hold the contactor in everything works
    8,236
    Try it with a paper clip in the machine trigger terminals. May be a bad gun.
    I've tried that I read a post somewhere else that said it was a bad resistor on the circuit board I'm trying to find out how to test them
