Results 11 to 20 of 25
    Dec 2012
    Simcoe Ontario
    91
    Default stick keeps sticking!
    It's the first thing you learn and you will never forget it. Sticking the rod that is. And ya turn it up to 125-130 ish scratch the rod a good couple inches ahead of where your gonna be welding and drag it back so when you get to the starting spot she's nice and hot
    Illinois
    612
    All machine settings are different. Like it was stated, raise amps. Just because it says 120 it maybe only 110. 10 amps will make a difference.
    Aug 2013
    15
    I've been doing alot of long arcing but everyone keeps telling me not to do that. Do you guys know why?
    Jan 2012
    Coos Bay Oregon
    22
    Long arc bad.... Keep you arc nice and tight, you have much better control of the weld pool. It sounds to me that you can't see. Change your body position and make sure not to reach. Got to be comfortable with a good field of vision, if not, overhead will be a constant struggle. Practice, practice, practice.........
    Sep 2009
    South Carolina
    571
    The advice abut using your free hand to hold the rod to help get started should do the trick.
    A lot of welders do that. I never did in the early days but I'll do it now in a second.
    I also never used a remote control but how sweet that must be to be able to start hot then fine tune as you go.
    Aug 2013
    15
    I can see and by long arcing I mean striking the arc on the vice and carrying it to the work piece.. But I've been using my left hand now to hold the rod like you guys said and it works great..
    Jul 2008
    East Tennessee
    615
    You should dip the rod in rod oil, that'll help. Old timers trick! !!
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1968 Redface Lincoln sa200
    Powcon 300st
    Aug 2013
    505
    Run it at 125 or a bit higher and keep you arc length around an 1/8 inch. Its sticking because you are running it too cold.
    Aug 2013
    15
    Ok how about open v groove either I stick or I blow holes and I try short whips and long ones..
    Jun 2009
    las vegas
    227
    Practice. Lots of it. I get a strip of metal and just strike till I get steady again.
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
