Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Aug 2013
    15
    Default stick keeps sticking!
    Hey everyone my name is Wil and I'm new to stick welding. Now every time I start a work peace mostly overhead I stick every time I start. I use a 1/8 7018 I try the tap way and the scratch and I keep the machine around 118, help please...
    Try leaving one hand on the rod for more control on your start. As you get it started pull your hand off.
    Jun 2009
    las vegas
    227
    Thats good advice your hand is most likley wobbly and hence the stick
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    May 2011
    Bossier Parish La.
    558
    That's one of the reasons it's called "Stick" welding.
    Illinois
    626
    What brand of rod ? Is material fairly clean ? Is ground clamp close ?
    Try running the rod tip across a flat file before using. there maybe a excessive coating on end. Try Lincoln Excalibur.
    Cave Creek Az
    1,048
    Or bump up the amps a wee bit.
    3,945
    Bump the amps up to about 125. You are using a DC machine right?...Bob
    May 2013
    East Tenn
    148
    Funny
    Quote Originally Posted by aametalmaster:310981
    Crank it up to practice striking an arc, when you become better you can lower your amperage.
    Aug 2013
    15
    They are Lincoln rods, and yeah it's on DC+.. I always grind the steel down before welding so its pretty clean.. I'm gonna try the holding the rod trick..
