    Aug 2013
    3
    Default Miller AEAD200LE wiring question
    Hi guys, got a question. I got an older welder that I would like to use as a generator. I do know it works and runs but is missing the rectifier. I found one on eBay for 25 bucks and I can wire that up no problem. My question is I see a few more cut wires if anyone knows where they go. I can pull the cover and trace but was trying to save time if possible. Are they going to the hot side or ground or ??
    Aug 2013
    3
    The wire that is not cut goes to the coil.
    226
    Do you have a manual and wiring diagram so you can trace those wires.
    Aug 2013
    3
    I was able to find a schematic of the wiring last night. I just have to stare at this mess for awhile to figure it out. I hope lol
