    Mar 2011
    21
    Default ideas/help/insight.......Cast iron pump
    I work at a waste water treatment plant and one of our pumps devoloped a pin hole in the cast housing and is leaking. I tried a cast rod but its paper thin and just opened up on contact and is now the size of a dime. Im thinking tomorrow to grab the mig gun with stainless wire and try to put a band-aid on it until we can rebuild it. any ideas or comments would be much appreciated. its up underneath and is dirty and i can even fit a grinder where it is..
    Thanks in advance
    Bill
    Apr 2012
    Western Pa.
    295
    If could get clean, Tig with Ni-rod or even SS rod would work in a pinch.
    Otherwise cut small patch just little bigger than hole out of 3/16 steel and I'd try Ni-rod and stick weld patch over hole.
    Jul 2010
    379
    Could you braze-weld a patch over top of the hole with an O/A torch?
    I just braze-welded a broken cast-iron C-clamp and it seems pretty darn strong!
    Sep 2012
    seaford de
    406
    I like to use silicon bronze with tig. Works great as long as you don't have to drill where u used it
    Mar 2011
    21
    thanks so far to everyone
    Mar 2011
    21
    ok heres how it went...this pump is 40ft underground with no power there so tig was out of question...i ran 2 extension cords to myMiller Multimatic 200 Auto-Set Elite Welder
    using stainless wire and a 90% helium 7.5% argon and 2.5% carbon mix it welded smooth even was in overhead position...thx for the help
