Results 1 to 7 of 7
    Mar 2013
    14
    Default Miller bobcat /p216
    Hey good morning anyone could assist me would be great.
    have a miller bobcat gasoline onan engine but I am not getting any spark to the plugs so far I check the coil and is ok any other thing that I can do ? And by the way it a two cylinder engine.model#p216-1/11519H.....s/n #L007189227 thanks in advance
    May 2009
    Central North Carolina
    150
    The most likely thing to check -
    There is an oil level switch that cuts off the ignition if the oil level is low. Check the oil level and be sure it's full. If it is, then it the level switch might be bad. Find it in your manual and temporarily jumper it out to see if the motor will start without it.
    If it does, don't leave the jumper on, replace the switch. If you don't you may someday destroy the engine when the oil level goes low.
    I'll try to find my manual and look for other possible causes, but my next reply won't likely be today. Maybe someone else will be able to help.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    Nov 2003
    3,725
    Thumbs up
    Quote Originally Posted by Stone View Post
    Here is a link to download the service manual for that engine...
    it is a Free PDF download from Onan...
    http://www.cumminsonan.com/www/pdf/manuals/965-0762.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Mar 2013
    14
    Default Miller babcat/.'
    Quote Originally Posted by CharleyL View Post
    Charley
    Thanks I will try that and let you know .
    Aug 2008
    Orange, TX
    1,223
    Actually it's just an oil pressure switch that opens with no oil pressure that cuts off power to the coil to save the engine in the event it runs low/out of oil. The switch is located under the air cowling near the oil filter.
    If the OP switch is OK then a likely cause is a bad ignition module that you can test based on the procedure in section 8 of the manual that H80N posted the link to.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Mar 2013
    14
    Quote Originally Posted by duaneb55 View Post
    Thanks I check it out ..let you know the results.
    Mar 2013
    14
    Hey I want to confirm that the problem was the oil unit did what you say and it work thanks again ....the machine needed and oil change and a good service.
