Results 1 to 3 of 3
    Default nitronic 50 parameters for gtaw
    Hey guys need help with parameter for nitronic 50 1.25x0.065 tubing can I weld without filler or do I have to use filler and can I use 316l or 309l?
    Apr 2010
    292
    Found this:
    Nitronic® 50 is readily weldable using conventional joining processes. Autogenous, high power density joining processes such as EB or laser welding, should be used with caution due to low FN potential and severe outgassing possibility in vacuum atmosphere due to high nitrogen content. When filler metal is added Nitronic 50W (AWS E/ER209) is recommended.
    http://www.electralloy.com/pdf/Nitronic_50.pdf
    http://www.electralloy.com/index2.php?page=consumables
    Also see WELDING in this doc about 308L/309 filler:
    http://www.electralloy.com/pdf/Nit_50.pdf
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    The recommended filler for that would be an ER209, but either a 308L or 309 can be used to make sound welds. I would recommend using a filler when welding and producing a nice convex weld to eliminate any chance of hot cracking.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
