Results 1 to 3 of 3
    Feb 2011
    10
    Default Syncrowave 350 problem
    Hello guys, my 350 is giving me a problem again. When I turn the machine on the panel reads 1 volt and 1 amp. The high frequency is running constantly, the switch for it is in start only mode.
    I can't get an arc established. The high frequency is working, but not enough amperage.
    I checked the wiring on the pedal, it looked good. I then removed the pedal and switched to *panel* setting.
    Does anyone have any idea what could cause this?
    Many thanks!
    Serial number is KA754122
    Feb 2011
    10
    I removed the side panel and found the 125630 circuit board damaged. Two resistors and an IC are heat damaged.
    Does anyone have a good source to have this repaired? A new one is very expensive.
    Jul 2008
    Wooster, Ohio
    18
    Quote Originally Posted by GregGood View Post
    Radwell has the board to my 250 dx. $675 to fix.
    Syncrowave 250 DX
    MillerMatic 212
    Hypertherm plaz
    Coors light on tap
