    Aug 2013
    Question Millermatic 211 Feed Problems
    What could cause a Millermatic 211 to not feed wire on 230v and not weld on 120v? I can hear a click in the board when I press the trigger on 230v but it will not feed. I tried it on 120v and it wont weld. Fan runs when the machine is powered on.
    There was a thunderstorm that struck a palm tree in my yard and fried the power supply on my computer fried 2 tv's, my modem and router. The welder was plugged in and I fear maybe the board is fried.
    Any tips appreciated.
    Apr 2013
    Southeast idaho
    30
    Default Millermatic 211 Feed Problems
    If those other electronics are fried I'd say the welder is probably to… one way to be sure though. Take it to a service center
    Mar 2011
    La
    323
    Were any of those components plugged into a surge protector? If not, that would have saved you a lot of head ache. Ja
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    Nov 2011
    164
    I would say definitely affected by lightning (if it was ok before the strike?)
    One of these
    http://m.homedepot.com/p/Square-D-by-Schneider-Electric-QO-SurgeBreaker-Surge-Protective-Device-Takes-2-Load-Center-Spaces-QO2175SB/100202111/
    Would help protect some electronics.
    Still recommended to use a primary surge protector though.
    2,957
    Check the selector switch for the Spoolgun/regular gun
    Aug 2009
    Ocala Fl.
    48
    How old is your welder ?? If it is under three years old ""Call Miller"" They will let you know what to do.
