Results 1 to 10 of 12
Thread: Bifocals
    Aug 2013
    Post Bifocals
    Hi I'm new here. Not sure if this exact question has been posted before? I wear progressive bifocal lenses and want to know (as I'm a student to welding) if there is a solution to either using a magnifying lens or something else to aid in close up viewing of the weld. In my personal situation welding at home I've found it difficult to see the weld start point especially using a fixed type shade. Just got an auto darkening helmet and haven't yet tried it out. I've found that I require a lot more light on the weld surface to see to begin. Is that common to those of us who wear bifocal lenses?
    Ron
    Mar 2013
    24
    Better light on the workpiece that doesn't trigger your auto dark is always an improvement. Not seeing where your rod tip is behind a #9+ fixed is not unique to either myopes nor presbyopes, and you will be amazed how the auto darkening hood improves your arc starts looking through a #3.
    Personally, I would get my Rx renewed if having trouble with my close vision and consult with the doc before adding more magnification in the helmet.
    Have fun with your new helmet.
    Dynasty 350
    Bobcat 250
    Maxstar 150S
    Titanium 9400
    Purox O/A
    Cutmaster 42
    Apr 2012
    Western Pa.
    298
    Default Bifocals
    Yep. Sure do. At 54 Ive lost my up close vision. I ware same type lens and found they can't increase my up close with out affecting long range vision. But I would rather ware them over bifocal glasses for work. I put a 1.00 magnifier in my welding hood, works great can now see weld puddle clear. I'm now up to a 2.00 in my hood all time.
    And I sometimes use a 1.25 par of reading glasses with the mag. Lens In helmet for very fine Tig work. Ya can't weld if ya can't see, guess just comes with age. Makes u appreciate the good vision I had for so many years. Wish I could get it back along with other things. :-)
    Greg
    Oct 2011
    Minnesota
    54
    Quote Originally Posted by gnforge View Post
    ... guess just comes with age. Makes u appreciate the good vision I had for so many years. Wish I could get it back along with other things. :-)
    Greg
    Been there, have the coffee cup and tee shirt. They say the mind's the 2nd thing to go. I can't remember what the first was.
    May 2010
    Central CA
    784
    Default Magnifing Glasses
    I use +2.50 safety glasses under my hood. For tig I use +3.00 for fine work.
    The lens that fit in the hood can have a different power on each side.
    But I found that they would scrach very easy.
    I just pick up 2 pair of +2.25 for general work and 2 pair +2.50 today.
    I misplace them all the time.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Sep 2009
    South Carolina
    571
    I have a 2.0 in my Jackson hood and nothing in my 100 buck Northern Tool hood.
    Both are auto dark, I tried the older Northern hood out about a week ago, after a few months of wearing the Jackson and I couldn't see crap. Really when it went dark it was dark.
    I put the Jackson back on and didn't try it again. So there are some real differences in the hoods. I can't believe I wore the other for over a year.
    It even scares me now to bring it as a backup.
    Apr 2012
    Western Pa.
    298
    Default Bifocals
    Glad to know I'm in Good company. Just remember we're as good once as we ever were.
    I can't remember either pin2hot.
    Bob- i could never find glasses that's why put lens in hood :-) you would think after loosing so many they would be laying everywhere, I think they have hidden legs.
    Finally bought a Miller Elite a year or two ago, little expensive but a super helmet for fab work.
    Cheap ones just don't hold up for every day hard work. Thanks guys its a elite group to be in, ya can't cheat your way in, you earn it. :-)
    Oct 2012
    4
    Default Bifocals
    I've had multi focal lenses and have yet to find an insert to work well. Best option for me was to have prescription lenses made specifically for welding with only near sight correction and large lenses. Now I can see pretty much everything. An auto helmet will help also as others have mentioned.
    I've been dealing with this issue for years now, been wearing bifocals for around 6-7 years and now find that I still cannot see good under the helmet...Thanks for the suggestions about the reading glasses...I already use +1.50 over my bifocals when reading small text or working on something small. I will give them a try under the hood. Keep on Welding!
    Dec 2008
    Arizona
    812
    Default Full Lens MAgnifiers!
    I wear these full lens magnifier/safety glasses and swear by them!
    http://www.envirosafetyproducts.com/...ety-glass.html
    They come in several diopters (magnification power), are very comfortable and a lot safer and cheaper than prescription glasses from the eye doc.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
