    Default Millermatic 140 with auto set
    Hey im only 3 years into welding and work at a company that manufactures industrial aluminum a.c. stands. At work I use a millermatic 251 with spool gun and weld usualy 1/8 aluminum tubing and I-beam.
    My side hobby is saltwater fish tanks so i know a number or side jobs involving fabricating standd and light racks ect.
    I found an almost brand new millermatic 140 with autoset and a miller spoolmate 100 can i weld 1/8 aluminum and 1/8 steel without problem?
    I want the machine to run on 110/120
    Any input will help
    Thanks guys!!
    226
    Pretty hard to burn the wire with one that small. I use a small one like that every once in a while pretty hard to do. Save your money for what you have been using.
    Thanks man i really dont want to spend the cash just to find out its too small
    How big og a generator would i need for a 251 or 252?
    Northern California
    219
    The manual for the MM 252 shows that when operated on 230 V, it requires a minimum of 46 amps and would need a 50 amp circuit breaker with appropriate-sized wiring.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
    2,968
    Your 120v requirement limits your choices
    My Passport plus will weld 1/8" AL on a 20amp 120v circuit
    I haven't tried the MM211 on 120v
    Your question about the generator suggests you don't have access to 240v at home for some reason
    Illinois
    660
    I don't do aluminum but have seen posts using the Miller 211 with spool gun. This may be the right machine for you reviewing the specs on it. It is 110/220 volts and the rebate is current until end of August.
    http://www.millerwelds.com/landing/build-with-blue/ REBATE INFO
    Sep 2007
    Medford MA
    544
    Quote Originally Posted by 120reefermadnes View Post
    Any input will help
    Thanks guys!!
    First, I agree with others regarding getting a more powerful machine if you can swing it. I have a MM140, I love it --- but I do know that it's limited and don't try things beyond where it can go.
    Second, it will do 1/8 steel no problem. I've never tried AL, but my impression of the other posts on the subject over the years is that its aluminum capabilities are at best limited.
    Third, the MM140 is a 110/120 machine. Just make sure that the circuit you plug into has 20A or so capacity and that you're not running other big current hogs on the same circuit (unless you like repeated trips to the circuit breakers :-)
    Finally, the machine itself is a good machine _within_ _its_ _limitations_ and as far as I can tell, none of its limitations are surprises.
    Frank
    So would the 211 be a better choice?
    I was also looking at the multimatic 200 because I would also be able to tig and stick weld if neccesary.
    What do you guys with all the expieriance think?
    What size generator(watts) do you guys use to run a MM211
