Results 1 to 6 of 6
    Aug 2013
    1
    Question Millermatic 211 Feed Problems
    What could cause a Millermatic 211 to not feed wire on 230v and not weld on 120v? I can hear a click in the board when I press the trigger on 230v but it will not feed. I tried it on 120v and it wont weld. Fan runs when the machine is powered on.
    There was a thunderstorm that struck a palm tree in my yard and fried the power supply on my computer fried 2 tv's, my modem and router. The welder was plugged in and I fear maybe the board is fried.
    Any tips appreciated.
    Apr 2013
    Southeast idaho
    30
    Default Millermatic 211 Feed Problems
    If those other electronics are fried I'd say the welder is probably to… one way to be sure though. Take it to a service center
    Mar 2011
    La
    284
    Were any of those components plugged into a surge protector? If not, that would have saved you a lot of head ache. Ja
    Dynasty 200 DX
    Diversion 180 (sold)
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
    Nov 2011
    159
    I would say definitely affected by lightning (if it was ok before the strike?)
    One of these
    http://m.homedepot.com/p/Square-D-by-Schneider-Electric-QO-SurgeBreaker-Surge-Protective-Device-Takes-2-Load-Center-Spaces-QO2175SB/100202111/
    Would help protect some electronics.
    Still recommended to use a primary surge protector though.
    Los Angeles
    2,927
    Check the selector switch for the Spoolgun/regular gun
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Aug 2009
    Ocala Fl.
    47
    How old is your welder ?? If it is under three years old ""Call Miller"" They will let you know what to do.
