Results 11 to 20 of 21
    Lodi, CA
    1,315
    Sig line is "signature line",,,, that's the place I'm repeatedly telling you I'm a dumb sh!t. I think most members here would agree, so take what I say with a grain (or two) of salt. Just being honest with you.
    Dec 2009
    Southern IL
    20
    at 26 volts with 045 you should be at 325-350 ipm. I would kick the machine up to 27 volts and use pure argon. When set up correctly and your speed is good it will be very quiet and no spatter at all.
    Mar 2012
    5
    Default pure argon mig
    pure argon on mild steel mig wont work properly because of cathodic sputtering
    better to use argon c02 mix
    Jan 2009
    Spence Spring, WV
    13
    Default what is your gas on.
    I weld from half inch to about 2 1/2" thick or more
    with preheat and set my gas from 40 to about 55 cfm.
    SMAW, GMAW, GTAW, FCAW
    ALL POISTIONS
    USN HT2 RET
    Jan 2009
    Spence Spring, WV
    13
    Default bear wire
    On bear wire between 20 and 40. Also watch your fan or breezes. I run around 24.5 to 25.5 and wire speed 385 to 390 works for me. My other comment was for flux core. I use C02 for Flux core and 75 / 25 argon / c02. For bear wire.
    ALL POISTIONS
    USN HT2 RET
    Nov 2012
    24
    Thanks everyone!! I changed the settings on the machine to 27 volts and 325 wire speed and that caused my travel speed to slow down. So far it seems like the problem is solved!! Thanks again for everyone's input.
    Nov 2012
    24
    Add Content
    Oct 2009
    306
    Why are you whipping your mig welds? Whipping your weld is what i think caused your porosity combined with a high travel speed. Also to the person who suggested using pure argon, the co2 stabilizes the arc without it you would have unwanted spatter and a hard time with arc stability.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Oct 2005
    North Central Indiana
    783
    Quote Originally Posted by sdwelder View Post
    1" thick 1018 plate
    .045 E70C 26.0 volts 410 wire speed
    CS6 gas.
    Back to back filet welds. First weld runs smooth and has zero holes. When I weld the second side the holes come up through the weld. Material is very clean. Sand blasted. Wiped down.
    Wrong gas setting? Using a different gun angle on the bad side?
    not near you
    148
    I would recommend using a largerdiameter wire for these welds on 1 inch plate....>045 is just too small......Flux core....
