Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Nov 2012
    24
    Default pin hole problems
    1" thick 1018 plate
    .045 E70C 26.0 volts 410 wire speed
    CS6 gas.
    Back to back filet welds. First weld runs smooth and has zero holes. When I weld the second side the holes come up through the weld. Material is very clean. Sand blasted. Wiped down.
    Nov 2012
    24
    Add Content
    Nov 2012
    24
    The vertical had holes that i filled. It looks like crap i know. Im going over it withTIG. Thanks in advance!!
    3,959
    Too much wire speed...Bob
    Lodi, CA
    1,315
    Too much wire speed, too much travel speed. Slow it down, put more bevel in if necessary, maybe use multiple passes. Looks like just atmosphere looking for a place to escape the puddle. Those holes are not porosity, they are not contamination.
    Nov 2012
    24
    Your correct. Not perosity. Too much wire speed huh? I will try turning it down. The settings on the machine were not put there by me. They had been programmed in by a Lincoln engineer. Maybe that's the problem. The machine is the wrong color. Ha ha. Thank you for the input.
    Lodi, CA
    1,315
    Don't matter if red or blue, I just looked at the picture you posted. Looked like way fast travel. I saw nothing right about it. Just remember, the theoretical is not always the practical, no matter what Lincoln or Miller tells you.
    Lodi, CA
    1,315
    But then again, read my sig line, don't pay attention to anything I say......
    Nov 2012
    24
    Right. The Lincoln thing was a joke. It's a spray mig setting. Flat position only. Not that it changes the fast travel speed or high wire speed. Just giving a little more info.
    Nov 2012
    24
    I dont know what a sig line is. But I will try everything you suggested. Not like its going to kill me. I appreciate any and all advice. Thanks!!
