Thread: Corten welding
    Aug 2013
    4
    Default Corten welding
    I'm just re-registered after a pretty long absence. I move from east coast to west and sold my Synchro 180 prior to moving, and yes, I regret it. I kept the 135. I'm going to pick up a 211 prior to months end. We are in the middle of a pretty significant re-model and I'm going to have to do a bunch of structural steel to open the floor plan up. Hence the 211. I'm kinda lusting after the 252, but at this point I'm a hobbyist and I think (fingers crossed) the 211 will do it for me. My heli-arc days are over. I can't make all the parts move at the same time in the right way, let alone see it. To my question...
    The house has an old stone skirt around it. Some has had to come off for foundation work but one side I am leaving. It stands about 5-6" proud of the siding. I am going to have to fabricate a flashing for this and think Corten would look good there as a cap. What wire would you use to weld Corten. Suggestions gratefully received.
    Wa
    625
    Why do you have to weld it?
    Aug 2013
    4
    Default While I guess...
    I could overlap it, I would prefer to go with a heavier gauge metal and have a continuous piece. I have access to a 10' brake and can fab up the pieces.
    Sep 2012
    AZ
    52
    Wa
    625
    I would just overlap it. No need to make a simple job hard.
    Dec 2008
    Arizona
    812
    Have you priced that steel? I recently got a quote of $450.00 for a 4 x 8 sheet of 14 gauge!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
