Results 1 to 10 of 12
    Default grinding out a curve on square or round bar.
    Is there any machine that would make grinding out a curve in order to hold round bar any easier/quicker?
    Try a hole saw in a drill press easy and cheap
    2,936
    Hole saw in a good drill press
    Edit- if you are only doing set ups like in yer pic then a hole saw in a DP but for any angles you'll need a Tube Notcher
    http://www.jd2.com/t-notchercomparison.aspx
    You can Google or you tube notchers to see how they work.
    Edit #2
    You can also use your Chop saw on Tubing
    http://www.pirate4x4.com/forum/shop-...-pictures.html
    Guys thanks very much, I just wouldn't have thought of the hole saw.
    Those pipe Notchers look great.
    Wa
    633
    I have the jd2 its pretty good. Had to mess with the alignment of the clamp when I first got it. It was little off center, but now it's good. Don't buy a cheap one or you will be fighting it
    No more cheap stuff for me, I've found that out the hardway better to save and do it right. Thanks again for the info. I
    3,950
    Make a template from sheet metal to trace it then use a torch or plasma cutter. Or make a thicker template that you can just run the torch around or a plasma cutter. Have the radius figured out for either the torch or pc to have it cut exactly where you want the hole. Should only be a minute on each side and they should be perfect with no grinding if done right...Bob
    Illinois
    632
    I don't have it yet, but this is on my list. Baileigh tube notcher TN 250
    http://metal.baileighindustrial.com/tube-notcher-tn-250
    Lodi, CA
    1,305
    I've always just cut these out with a torch, dress up a bit with a grinder. Unless you are doing hundreds and thousands of these, I cannot understand spending stupid amounts of money to replicate the same cut, over and over again.
