Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Default mm251 stutters and pops
    And for you removing that feature has actually helped your arc starts or overall weldability. I love my 251 and have never had issue with starts. I just can't use factory recommendations as they are never even ball park. What kind of steel projects are you blasting with that black beauty abrasive.
  2. #22
    Oct 2005
    North Central Indiana
    779
    Quote Originally Posted by Texas113 View Post
    Yes! Miller told me to do it.. and it helped/worked, not all 251 machines have the start up problem it seems. Right now I'm working on a brake drum forge, Im using black beauty to take rust off steel I salvaged from a 275 gallon oblong oil tank to build a wind screen around the back of the forge.
