Results 11 to 20 of 22
    Oct 2005
    North Central Indiana
    782
    Here's the blaster Texas, we better not use the word bo-mb, Obama's police will come and get us.
    http://s1298.photobucket.com/user/cy...Sand%20Blaster
    Sep 2012
    seaford de
    406
    isnt the machine still under warranty?
    Oct 2005
    782
    Quote Originally Posted by weldonwelding View Post
    No it's a 2003 model. I think it's the heavy fiber spool that's at the heart of my problems.... could be the hole in the fiber spool isn't perfectly round and it's square cornering a bit as turns too. I'll check everything out and change the liner tomorrow. Something isn't right, It welds good until the sputtering starts. Seems to sputter on starts a lot that's why I'm thinking the weight of the wire could have something to do with it .
    Oct 2005
    782
    Quote Originally Posted by gnforge View Post
    I would also check the ground cable. They can act that way if ur loosing good ground. I personally don't like the OEM ground clamps, I replace them with a good brass one even on a new Michine. That Michine should handle a 44 lb. spool with no problem.
    I would at least ck all ground connection nuts and grind area bare to connect ground cable.
    Just a thought. Greg
    Greg, I pretty much did what you're suggesting. thanks
    Oct 2005
    782
    Default Fixed stuttering and popping
    If you have a 251 that stutters and pops on starts you can remove the # 8 or #79 wire (depending on your machine) from the contactor block and your problems will go away... at least mine did. My 2003 MM251 has never welded so nicely since I pulled the # 8 wire off the contactor. Thanks Miller for the Tip The #8 wire is the wire with the yellow marker on it.
    http://s1298.photobucket.com/user/cy...y/MHS%20Remove
    Default mm251 stutters and pops
    I like that blaster. What kind of abrasive you using for the stated applications.
    What is the purpose of the #8 or #79 wire? Is it something to remove only if it stutters and pops or something that can change characteristics of a good running 251.
    Oct 2005
    782
    Tex, the #8 or # 79 wire removes the hot start from the machine... It seems to me the machine is welding much better in all respects period.
    I run Black beauty through the blaster. I use a 1/8 pipe for the nozzle instead of the ceramic 3/32? nozzle Texas Blasters sent me with their hose. It was to small of a hole. The black beauty would plug the hose at the tip with the valve just barely cracked. In order for the media to come out so little of it could be sent through the hose it was hopeless to get anything done.
    Please clarify one thing for me. What exactly is hot start and its function.
    Oct 2005
    782
    This technology provides a smooth, spatter-free start. No pop-gun starts or spatter to clean up. It gives a temporary burst of energy on start up to help initiate the arc.
