Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Oct 2005
    North Central Indiana
    783
    Default mm251 stutters and pops
    Could a mig gun cause a MM251 to weld, sputter and pop, weld, sputter and pop again? When it welds it welds good for a few inches. IT's stutters on starts too. The machine is like brand new, it's only had one 33 lb roll of solid wire through it. it's getting worse, I could deal with it before today, but today was the last draw.... it's almost 44 mag time.
    Salem ,Ohio
    3,972
    Cool
    I would try a new liner. Remove the tip and loosen the wire from the drive rollers and see if it pulls thru freely. And also check the 5/8" nut on the center of the spool and make sure it isn't tight. Mine has to be run almost off...Bob
    Oct 2005
    783
    Quote Originally Posted by aametalmaster View Post
    Thank you Bob, I'll go over the machine tomorrow. I'm going to buy a new Bernard gun for it if it's not the machine's electrics, the Q3015AE8XM model. Do you use Bernard guns? Do you like them?
    Aug 2010
    west tx
    10
    I agree with Bob. I would try a new liner, I highly recommend benard. They use "centerfire" tips I believe, they have no threads on them and work great
    Trailblazer 275DC
    eleite helment
    millermatic135&140
    375extreme plasma
    new set victor torches
    ingersolrand 185 compressor
    1 big f550w 8 4ft toolboxes full of tools
    o and the rest is too much to list lol
    im very blessed to have all of it paid for
    Oct 2005
    783
    Quote Originally Posted by K.C. Brashear View Post
    Thanks Brasher for your commenting...
    I just checked Lincolns website, I must have a 44 lb spool of their ER70S-6 on the machine because I don't see a 33 lb fiber spool of it offered. That's a lot of weight, could be it's to heavy for the machine. Tomorrow I'll put on a 10 or 12 lb ? roll and see if that helps. I'll post back here tomorrow the results.
    4,506
    Make sure the ground clamp is good. I wouldn't be buying a new gun till I figured out what was wrong.
    Apr 2012
    Western Pa.
    335
    I would also check the ground cable. They can act that way if ur loosing good ground. I personally don't like the OEM ground clamps, I replace them with a good brass one even on a new Michine. That Michine should handle a 44 lb. spool with no problem.
    I would at least ck all ground connection nuts and grind area bare to connect ground cable.
    Just a thought. Greg
    Oct 2005
    783
    Quote Originally Posted by Sberry View Post
    I put a new Linco 300 amp copper ground clamp on it this spring, buying the new gun is OK, I'm getting the machine fixed if it needs fixing, fixing it is cheaper than buying a new one ..... I need to buy a new sandblaster too, my homemade one is supposedly a bomb.
    I too like the Bernard guns for heavy use. Tackit I am interested in seeing some pictures of your "bomb" that you currently are blasting with. HaHa blasting and bomb used in the same sentence, wonder if that puts me on the "list". Seriously I would like to see how you built your sand blaster.
    Oct 2005
    783
    Quote Originally Posted by Texas113 View Post
    Texas I can't figure out how to use Miller's picture posting software and I can't remember if I have the blaster pics on my photo bucket account, if not I'll have to find the pics and run them through photo bucket and then post the link here.
    Happy to help a Texan.
