Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
  1. #31
    Gotchya, that makes sense... when I run into this problem I'll make another posting on the forums ( if I can't educate myself enough to make the conversion)
  2. #32
    2,955
    Quote Originally Posted by AwesomeAlbert View Post
  3. #33
    May 2013
    East Tenn
    148
    Default What generator would be good for a mm200?
    Broccoli, what gauge wire is that?
  4. #34
    2,955
    Quote Originally Posted by Precision View Post
    10g but it is a heavy duty jacket on it.
  5. #35
    Thanks Broccoli, I set the pigtail up as per your diagram and it works like a beauty. I wound up goin with a 7k continuous watt "CHAMPION" from costco (they have an awesome no-questions warranty program there.) And thanks for all of the input guys, it has been very educational!
  6. #36
    Default Generator for MM200
    So I have a MultiMatic 200 and I'm wondering what generator I get to run my welder at MAXIMUM performance? Got any suggestions? Thanks guys!
    I would suggest the Honda Black Max. I bought one at the local Sam's Club. It has 8700 starting watts/7000 continuous. I run a Miller 211 off it as well as a Dynasty 200 DX, and a Lincoln Invertec 155. It will also run my Hypertherm PM30. It retails for $999. in my area. Hope this helps
