Results 21 to 30 of 36
  1. #21
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Cruizer,
    That is some good info about generators. Never really crossed my mind. Do you know of any manufacturers that are making newer generators, other than the inverter generators, that are putting out power clean enough to not worry about running the smaller machines off of or do they all need to be put on a scope to be checked??
    Also, is there something that I can use ( an attachment of some sort) to help clean up the power on the generators that I have. I have been fortunate enough to not have had a problem yet, but I am not trying to sit around till I do. I am hooking up the Passport Plus and the Maxstar 150 STL to it. How sensitive are they?? Thanks
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
  2. #22
    Thanks for the input guys! a miller generator/welder is a little out of my budget, I just bought the Multimatic and love it! Im thinking of getting either a Generac GP7500E, or the Westing House WH7500E. Any body know witch one is a better piece of equipment? Thanks again fellas!
    Generac-
    http://www.amazon.com/Generac-5943-G...377330&sr=1-22
    Westing House-
    http://www.amazon.com/Westinghouse-W...6377330&sr=1-6
  3. #23
    2,955
    Quote Originally Posted by AwesomeAlbert View Post
    Generac-
    Westing House-
    http://weldingweb.com/showthread.php...erac+generator
    scroll down to post #6
  4. #24
    Quote Originally Posted by Broccoli1:310557
    Quote Originally Posted by jpence38 View Post
    Considering the input power needed to run your machine, I would say that a 3000 continuous watt generator would be plenty. As for the brand, that would depend on your budget.
    That's still way too small for the multimatic
    3000/240v= 12.5 amps
    The Multmatic draws 18amps at rated 150 welding amps Mig and 20 amps Stick
    20amps x 240v = 4800 watts continuous so yer looking for a genset that is around 5500watts
    So a 5500 watt generator would would be ideal, but as a couple other users stated I'm going to be using other tools and lights on the generator. So I figure a 7500 watt would be more than sufficient. I was just wondering between which of the 2 generators I should go with that I put in the previous post.
  5. #25
    2,955
    Yorkie on welding web uses a generac with good results- that is his 2nd one- first one just too many hours so he bought a new one.
  6. #26
    Gotchya, I missed that link on your last posting. Im thinking of going with the Generac, online reviews give the Westinghouse better statistics though
  7. #27
    May 2013
    East Tenn
    148
    Default What generator would be good for a mm200?
    If you do end up buying the Generac or another generator that has the 14-30 plug you will need an adapter to the 6-50 on the welder/cutter. EVSEadapter.com has some pre wired ones that are reasonably priced.
  8. #28
    May 2011
    Bossier Parish La.
    560
    We have a NICE Kohler generator at work, that could easily power Two of those Multi Matic 200's a few grinders, an air compressor, some lights, and a small subdivision all at once with no problem. But it's only 300KW. If you want, I can get the model number for you. Hey, he never said it had to be easily transported. But on the right truck it wouldn't be a problem, even with the fuel supply and distribution center. It has a 500HP Detroit Diesel, 6V-92. Plenty of power for this application.
  9. #29
    Quote Originally Posted by Precision View Post
    but the multimatic200 has the fancy MVP hook up, so will that still be necesary?
  10. #30
    2,955
    Yes- the MVP 240v plug is a 6-50
    The receptacle on the genset is an L14-30
    You'll need a pigtail to plug in to the genset or make an extension cord with the L14-30 on ne end and the 6-50 on the other end
