Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
    Default What generator would be good for a mm200?
    So I have a MultiMatic 200 and I'm wondering what generator I get to run my welder at MAXIMUM performance? Got any suggestions? Thanks guys!
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Considering the input power needed to run your machine, I would say that a 3000 continuous watt generator would be plenty. As for the brand, that would depend on your budget.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    4,457
    A MM200 is pretty hefty, its a 50A service machine. I would think 8 K or better.
    northern NJ
    1,910
    Quote Originally Posted by Sberry View Post
    He's talking about the new multimatic 200 not the old millermatic 200. The MM200 threw me off also. Just shows some of us are getting older.
    MM250
    RCCS-14
    Hahahah! Sorry guys, I was just trying to abreviate my title... But I have a coleman that's rated at 3600 continuos, It has an 8 hp brigs and straton on it, its older.... when I start to weld itbogs down and dies on minimum settings. And as for quality either 1st or 2nd teir brand name generators
    Los Angeles
    2,932
    Quote Originally Posted by jpence38 View Post
    That's still way too small for the multimatic
    3000/240v= 12.5 amps
    The Multmatic draws 18amps at rated 150 welding amps Mig and 20 amps Stick
    20amps x 240v = 4800 watts continuous so yer looking for a genset that is around 5500watts
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Sorry about that. You are definitely right about the wattage. I was stuck on stupid for a minute and was estimating from my head and posted the wattage on the 120V side instead of the 240V.
    As for the brand, I have always went with the Generac and have never been disappointed.
    In my opinion, Generac and Honda are at the top of the list.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    May 2013
    East Tenn
    148
    Broccoli is right on point. Also you gotta think if you are gonna run lights off of it, tools etc etc etc. I would go at least 7500.
    Sep 2009
    South Carolina
    571
    I'm surprised somebody hasn't already suggested an engine drive weld machine.
    A bit more weight and price but you can open many more doors by going that route.
    Quote Originally Posted by Hardrock40 View Post
    Not to mention a miller or lincoln gas welder costs less than an equivalent Honda. Also to be noted is engine drive welders advertise continuous watts not peak watts like generators
