Results 1 to 3 of 3
    Jan 2013
    20
    Default 3mm weld on 1/8 alum
    Hi all
    I've been asked to archive a 3mm tig weld on 1/8th aluminium with 100% penetration.
    I can't go bigger than 3.5 mm.
    There has to be some burn through to be machined off after.
    I don't think this can realistically archived.
    Does any one have any ideas? Can any one do this?
    I been tig welding for 10 years. This is the weirdest project yet.
    Oct 2012
    yuba city, CA
    66
    Default 1/8" weld on 1/8" Al?
    Quote Originally Posted by IanHerbert View Post
    Hi all
    ???and the joint is a ?????
    ??? and the joint prep is ???
    ???and the 3.5 mm (.140 in.) max. dim. is measured how???
    ???and the parent Al is ????
    ???and the Al filler type is ???
    ???and the machine used for this is a ???
    Jan 2013
    20
    Fillet and square groove
    0 prep right now, but I'm trying to get that changed.
    3.5 mm measured the usual way by leg length
    Material is 3003
    Filler 1100
    And using a miller dynasty.
