Results 1 to 10 of 18
    Sep 2009
    South Carolina
    571
    Default 12/3 so p 123-72-msha
    Got about 200' of this for 20 bucks. A friend had it in his shop and never used it due to the weight and length.
    Running from an engine drive to a 211, how long would I be able to make an extension cord? I have seen post about this but not finding out enough.
    Here in the manual for the 211, page 22
     When calculating max. cord length, remember to include conductor length from line disconnect device to input power receptacle.
    Input Voltage
    Input Power
    Phase Hertz Conductor Size Max. Cord Length
    120 V 1 60 14 AWG 27 ft (8 m)
    230 V 1 60 14 AWG 53 ft (16 m)
    http://www.millerwelds.com/om/o239988j_mil.pdf
    And that's 14 gage that you can run 230v twice as far as a 120v?
    Anyway, What would be the max length with 12/3 SO from the engine drive 230V receptacle? if possible?
    I have made a few extension cords but always thought 12/3 was too small so I figured I would ask if this can be used with 230 for the 211.
    2,909
    You could run it out 100'
    You'll get some voltage drop but the 211mvp can handle the drop in voltage-and due to the duty cycle of the machine you won't burn up the cord.
    You'll need to adjust settings as it may not weld the same as what the door chart reads but we adjust anyway.
    You also have consider that the 14g in the manual is for RATED output 150amps.
    The only problemo with 12g is that it doesn't fit very well in 6-50 connectors- just so small.
    But it was free
    Sep 2009
    South Carolina
    571
    This cord is huge compared to 12/3 from Lowes. I mounted them to install on e track, easy to move into the trailer. But the SO is a bit heavy for that even and probably wont get moved around much unless I can cut it down and use it to run the 211.
    Sep 2009
    South Carolina
    571
    100' is more than I thought. I might give it a go.
    2,909
    Don't use it coiled up like that- run it out or loop it in figure 8's on the ground.
    We keep ours at 50' lengths- 100 is just a PIA
    Sep 2009
    South Carolina
    571
    OK, good deal. Thanks
    Nov 2012
    Northern Arizona
    528
    Quote Originally Posted by Broccoli1:310440
    I've never heard that on the ac side. So why?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Apr 2010
    278
    It can get very hot if it's coiled up and you have a heavy load. I've seen pics of cords on reels that melted and caught fire.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    Nov 2012
    Northern Arizona
    528
    Copy that! That would be cool to see, but not in my shop... I know I have gotten things pretty warm when really cranking. I wouldn't want to start a fire. Thanks!
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Apr 2010
    278
    Here is a thread about a reel that melted and burned - an electric heater was the load.
    http://weldingweb.com/showthread.php?t=201381
    Miller stuff:
    Dialarc 250 (1974)
