Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    732
    Default Miller Matic 252 Slipping
    I have a MM 252 with a 15 foot fairly new Bernard 300 gun. The wire seems to be slipping when it encounters resistance. I checked tension and for a moment tightened it all the way up with a little more success, but I do realize that is not the solution. In addition I removed the drive wheels and removed the gun then reinstalled them. Do you have any other suggestions.
    Thanks,
    Jun 2013
    PacNorthWest
    67
    I'm too new at this to be a lotta help (got my used 252 about a month ago) but the 252 can take a LOT of different rolls, etc - do you have the right combo for your wire? Steve
    3,953
    What size/kind of wire? I run a MM252 all day everyday with .045 gas flux core and i had problems almost everyday. Then i got to swapping a knurled roller for a smooth one and the problem went away. You can switch rollers to suit even though they are stamped for a specific size and wire type. Read it somewhere in a Miller manual...Bob
    Nov 2011
    159
    Try 6-4 aligning drive rolls if you DO have the right combo
    http://www.millerwelds.com/om/o230693j_mil.pdf
    Aug 2008
    Orange, TX
    1,216
    Even though it may be a fairly new gun, it could have a kinked liner. I've seen brand new guns that got kinked right off the bat. Easy enough to pull and check out if you determine it's not a drive roll issue.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    732
    Quote Originally Posted by BukitCase View Post
    Yes they are the correct size.
    732
    Hey Bob,
    I am running .035 solid wire with the .035 roller. I pulled them off and reinstalled them. I will check the manual.
    Thanks,
    732
    Quote Originally Posted by ericher69 View Post
    I will give it a shot in the AM.
    Thanks,
    Duane,
    I will check the liner.
    Mar 2012
    Brookshire, Texas
    21
    Try loosening the tension on the spool itself, if it's too tight then that could cause your problem
    Oct 2009
    Reno, NV
    299
    Quote Originally Posted by S.A.W View Post
    Very true....remember, after getting the wire feed to be reliable the only thing that is truly important is that the reel not "over run" when the drive rolls stop pulling the wire, so set the friction (tension) on the reel as loose as you can without getting over run and birds nests!
    Don J
    Reno, NV
