Results 1 to 10 of 16
    Default 200 DX Can't DCEN Stick ??
    Owner's Manual:
    1 Polarity Control - Press switch pad until desired LED is illuminated.
    DC - Machine is set to DCEN (direct current electrode negative) for TIG welding, and to DCEP (direct current electrode positive) for Stick welding.
    AC - Use AC (alternating current) for TIG and Stick welding.
    Is this machine not capable of DCEN Stick? Maybe I'm reading something wrong or is it ok to swap the cable connections??
    Sorry, just not finding documentation that states this and I don't want to swap the cables and blow the thing up. :-)
    Apr 2010
    296
    How would it know you swapped the leads?
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    LOL Good Point. :-)
    Jun 2013
    PacNorthWest
    64
    Just out of curiosity, what are you doing that you'd even WANT straight polarity on stick??!? Steve
    I just got this machine and doing my homework reading the manuals and figuring out what it can and cannot do before firing it up.
    My curiosity must be satisfied. :-)
    Also it seems that most machines (while few) I've owned or worked with had either a DCEN selector or tap mod AND the 200 DX will do DCEN Tig I just 'assumed' it would probably do DCEN Stick.
    Hopefully this thread will result in an authoritative "yes it will" or "no it won't".
    Oct 2011
    Minnesota
    54
    Quote Originally Posted by BukitCase View Post
    Many moons ago whilst out in the boonies and needing to cut something, like corrugated culvert for example, I'd swap the leads on the AEAD, max the amps, and hit it with 6010. It did the job.
    Jun 2013
    PacNorthWest
    64
    Good point - it's been a LOOOONG time since I'd needed to do that, had A/O torches since the '70's and a Hypertherm plaz for the last couple years, guess I'm gettin' spoiled Steve
    Jun 2013
    PacNorthWest
    64
    Oh, unless you just wanna spend a lot more $$$ on tungstens AND lose maybe 90% of your capability, there's also a reason why your tig is DCEN - check out the link to the "tungsten book" in one of 80N's recent posts for more... Steve
    Amazing how easy it is to get an opinion but not an answer. :-)
    I wrote Miller tech. When I hear back Monday I'll post the answer here.
    Asking them is probably a better approach going forward anyway.
    Los Angeles
    2,934
    Quote Originally Posted by stickermigtigger View Post
    Swap the leads
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
