Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 57
  1. #31
    Nov 2003
    3,846
    Quote Originally Posted by makowicki View Post
    Looking at pictures and some of the specs almost seems to be a knock off with blue paint. I will have to stop LWS and see what they know.
    Knock off of what???...
    Sure would not think so....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
  2. #32
    2,970
    Knock off of their own equipment
    They already have the technology from their Dynasty and Diversion series stuff.
    Just put it in the 212 or 252 case and ta da !
  3. #33
    Nov 2003
    3,846
    Red face
    And all this time I was under the misaprehension that a "Knockoff"
    was a copy of somebody elses work...
    Who-Da_Thunkit...
    My Blue Stuff:
  4. #34
    Aug 2010
    1,184
    Sounds interesting... when are we going to get details??
    Upgradeable and Expandable
    Front panel memory card data port provides the ability to easily upgrade software and expand product features
    And the Owners/operators Manuals.. released soon????
    So they took the Dynasty280, detuned it, called it a Syncro, and shoved it into a Millermatic cabinet. I like it.
    http://www.millerwelds.com/pdf/spec_sheets/AD4-6.pdf
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  5. #35
    Jul 2010
    386
    Quote Originally Posted by Helios View Post
    Sounds like a good way to "muddy the waters" regarding the distinction between transformer-based versus inverter-based machines.
    It also sounds like a good way to pˇss away the good name of the Syncrowave BRAND.
    Personally, as a hobbyist/weekend warrior, I wouldn't own an inverter.
    That's why I chose a Syncrowave 250.
    I suspect there are a lot of other welder purchasers in the same boat.
    Up until now, if someone mentioned a "Syncrowave," everyone knew they referred to a transformer-based machine. Not anymore.
    Now, for the first time, when we talk about Syncrowaves, we'll have to talk about whether they're transformer machines (all except the 210) or inverter machines (the 210).
    How's THAT for branding, folks? I bet it took an MBA to come up with that!
    What's next? The Miller "Pinto" ... or maybe the Miller "Edsel"? Or how 'bout "The New Miller" ... like "The New Coke"?
  6. #36
    Apr 2010
    324
    The duty cycle seems low, though that may be conservative. On stick, it's 150A @ 20%. My TA 161STL is rated 160A @ 30%.
    And a max OCV of 47 Volts?
    The Sync 210 manual has been added to the manual section.
    http://www.millerwelds.com/om/o261726a_mil.pdf
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
  7. #37
    NY
    99
    Does it come with a internal water cooler? Or will it have to be a add on?
  8. #38
    Nov 2003
    3,846
    Thumbs up
    Quote Originally Posted by USMCPOP View Post
    Thanks Pop...
    That Operators Manual clears up a lot....
    Maybe they will develop a small water cooler to tuck into the side compartment....
    a water cooled torch would broaden its market and make it a neat little all in one lite industrial TIG...
    A lot of people don't need the features and complexity of a Dynasty 200DX but do need a bit more than a Diversion 180..
    this should fit right in...
    Could also see it equipped with a water cooled Micro TIG torch like a WP-125
    http://www.arc-zone.com/index.php?ma...cPath=13_18_39
    or WP-24W
    http://www.weldcraft.com/products/wp-series/wp-24w/
    would fit right in with jewlers, injection mold repair and university labs... and a bunch more places...
    It's simple setup could open up new applications for less sophisticated operators...
    My Blue Stuff:
  9. #39
    Nov 2003
    3,846
    Thumbs up
    Do wonder what doors might be opening up in the low amperage TIG automation arena with "Memory Card" and firmware upgradability... a USB pipe is a tiny step more.... that is if it does not Already have a built in "Diagnostic Port"....
    There are lot's of places where a small affordable programmable supply could be used...
    Small scale CNC is now quite common.. in areas like Plasma Tables and milling machines...
    no reason that welding could not be incorporated into the mix...
    My Blue Stuff:
  10. #40
    2,970
    Interesting marketing trivia with the "New Coke"- when they launched it it was a disaster as everyone pretty much knows but when they switched back and came out with Coke Classic they took back more market share than they had with the original Coke. Accidental genius marketing
