Results 1 to 10 of 11
Hybrid View
    Default Miller matic 252 wire feed issues.
    I have a 252 that is New. Maybe burned 3 rolls of wire on it. Was welding with it Saturday and it got to welding like I didn't have enough wire speed. Going to call Miller tomorrow because it's under warranty, like i said it's only a few months old. Any body have any idea what could be wrong?
    Nov 2012
    Northern Arizona
    566
    Did you go through the basics? Blow out the gun liner, check your lead connections at machine, check ground connection, make sure the wire tension is right, clean contact tip, etc?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Mar 2012
    Brookshire, Texas
    21
    Gotta side with Elvis here, you need to go thru the troubleshoot process before you go through the hassle of warranty work, check your wire tension, make sure your rollers and tips match the size wire you are using, clear your liner and make sure your settings didn't change, change in voltage could cause your problem
    Yes, I've done all the easy checks......
    Quote Originally Posted by S.A.W View Post
    Nov 2012
    Northern Arizona
    566
    Well, did you call? What was the recommendation?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Salem ,Ohio
    3,963
    Cool
    I had a brand new MM252 with similar issues. The 5/8" wire spool nut was too tight. Almost backed it clear off before it worked well...Bob
    May 2010
    Central CA
    788
    Sometimes the wire does not come off the spool even. It could be bird nested somewhat.
    Or it gets wedged between spool and the rest of the wire.
    It just comes off the spool hard.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Little Rock
    41
    Wire is sold as either wound or "precision wound" (or some other such descriptive phrase). I always order the precision version at little or no more cost.
    I realize this may be hype but it occurs with reputable retailers and brands and I have had no problems using it.
    Default Bad gas.
    My gas was down to around 500 psi , Change the bottle problem solved.
