Results 1 to 2 of 2
    Jul 2008
    Flin Flon & Creighton area
    233
    Default Water cooler hose for Coolmate 4
    Hello, I was wondering if there is a specific grade of rubber hose that should be used with the water cooling systems for a Tig Cooler. I was planning on using the green ribbed rubber stuff that i have made inert gas hose out of, i think its Parker branded. I need some really robust jumper hoses to run from the cooler and the torch saver i'm going to install , and then join the actual torch hoses with the couplers. I need a fairly custom length set up and thought most of the manufactured hoses might be a little prone to damage. I have read that the Tig coolant can react with different types of rubber and cause it to deteriorate.
    I have a welding addiction
    Nov 2003
    3,824
    Your LWS probably has some more "Official" stuff..
    But I have used Rubber Fuel Injection hose in the past with good results...
    It is plenty rugged, will easily withstand the 60psi of the coolmate and will not react with the coolant...
    Like this stuff..
    http://www.autozone.com/autozone/acc...er=240844_0_0_
    My Blue Stuff:
    Dynasty 350DX Tigrunner
