Results 1 to 8 of 8
    Default New 200 DX - Now What Consumables To Buy
    Dynasty 200 DX on the way to my house. drool...drool...pant...pant... :-)
    I'll be doing mostly mild steel first then some SS and aluminum every now and then. No odd alloys. Max thickness 1/4 or less.
    All scrap metal to start as it's practice practice practice to begin with. I'm not a shop.
    So if you were in my shoes what would tungstens and filler wires you take home with a new rig? It comes with 2% Cerium tungsten-1/16, 3/32, 1/8.
    Nov 2003
    3,641
    Quote Originally Posted by stickermigtigger View Post
    Congrats... you will love it....
    just get an assortment of 1 lb paks of 1/8 TIG rods to start.. then buy rod as you need it...
    As far as tungsten goes... you might take some time and read the Diamond Ground Tungsten Guidebook...
    http://www.diamondground.com/TungstenGuidebook2013.pdf
    Educating yourself in tungsten selection and prep is self defence against LWS counterpeople that are either behind the times or lazy....
    selection for inverters is different than transformer TIGs
    Usually I would be telling you to download the FREE Miller TIG Handbook....
    but they have taken it down... Rumor is that it is being updated and revised and will again be available for download... I hope that is true...
    http://www.millerwelds.com/resources...9-TIG-Handbook
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Good advice, thanks. Luckily I downloaded the Tig book the same week they pulled it. :-)
    Nov 2003
    3,641
    Smile
    Glad you got a copy...
    contrary to what we were told... have heard some rumors that it will be revised modernized and a PDF reposted.... Surely hope that is true..
    NO idea on the timeframe though...
    My Blue Stuff:
    1,914
    H80N wrote --- just get an assortment of 1 lb paks of 1/8 TIG rods to start.. then buy rod as you need it...
    You'll want more than just 1/8" tig rods. Some 1/16" & 3/32" for lighter stuff. ER70S & 308 ss
    Nov 2003
    3,641
    You are very right....
    was a long day... brain out of gear...
    I had meant 1/16 to start... but they are cheap enough.. to get a bunch of sizes..
    My Blue Stuff:
    After doing some of the recommended reading I decided to start off conservative and just take home a couple pounds each of ER70S6 in 1/16 and 3/32. I've got a good bit of mild steel to practice with. Will save SS and Al till I've developed some proficiency with mild steel first.
    Nov 2003
    3,641
    Thumbs up
    Wise approach...
    When you do decide to broaden your selection you might consider getting a pound each of ER4043 & ER5356 they are good general purpose Aluminum fillers
    AND
    a pound of ER308L Stainless Steel filler rod
    that should cover you for 95% of your everyday needs... then you can pick up more job specific and or exotic fillers as needed...
    I cannot say enough good stuff about the Dynasty 200DX... it is just a superb machine....
    My Blue Stuff:
