    Sep 2012
    26
    Default weld on mcCormick CAN!!!!
    I tried a dynasty 350 welder to try to tig it . it will work fine on 5 amps and 1/16"rod . The weld did not sink or burn through. Is there any applications for tig welding metal that small?
    Sep 2012
    26
    I previously tried the same thing with a thermal arc welder which bottoms out at 12 amps. the result is that the weld sunk. i looked back on the other side, it had no burn through but pushed through!!!!!!!
    Nov 2003
    3,626
    Quote Originally Posted by jamesmg View Post
    That Dynasty is a wonderful machine....
    but what is a "mcCormick CAN" am unfamiliar with it...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2011
    Minnesota
    54
    possibly a spice tin?? see here
    Nov 2003
    3,626
    Mebbe...??
    but wonder if that is what the OP meant...??
    PICs..???
    Ya might find this interesting...
    Welding Razor Blades - Low amperage Tig Welding Tips .
    http://www.youtube.com/watch?v=WSi5eRTIOa4
    My Blue Stuff:
    Sep 2009
    South Carolina
    571
    Yea applications are out there. I have had a few, A 4-wheeler gas tank was so thin I had to let it burn back to have some thickness to start on.
    Oil tank cover on a bike. Mower muffler. It helps to have smaller filler wire. 1/16 can make you use more heat. I have used some .030 mig wire when needed.
Tags for this Thread
