Results 1 to 10 of 12
    Apr 2013
    5
    Exclamation patching a hole in fire sprinkler system
    a friend of mine asked me about repairing a 2inch round hole on a pipe for a fire sprinkler system in a warehouse. He says the pipe is around 3/16 thick.. there is no pressure or water in the pipe now... he has a 90amp flux core welder from harbor freight. can i actually cut a section of new pipe and put it over the hole and weld it? I'm a certified welder but not for pipe. (not yet at least)
    WY...armpit of U.S.A.
    659
    I'm a bit confused by the mention of the 90 amp HF welder...were you planning on using it for the job? Is there a reason you can't cut out the bad section of pipe, rethread, add a coupler and short section of pipe instead doing a patchwork fix?
    Lets face it, the only time this piece of equipment is going to be used is if there is a fire. With a fire will come an insurance claim. Do you or the guy wanting the job done really want to go up against the insurance company's investigator admitting you were trying to go cheap on the fix? Can the job be done...sure. With the HF flux core welder...maybe/probably. Would I want to be on the receiving end of the lawsuit waiting to happen...not especially. Give an insurance company a chance to find an 'out' so they don't have to pay a claim, even though it may not compromise the system and works perfectly, and they will jump on it faster than a warehouse owner looking for a cheap fix.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Illinois
    635
    Verify on site for exact size of pipe and what hole looks like. Then check on a mechanical tee for the repair. You may get lucky and be able to install this fitting and plug or install a valve and nipple in threaded opening. No welding required.
    http://www.bing.com/images/search?q=...+tee&FORM=IGRE
    Wa
    644
    Your a certified welder but have no welder?
    Apr 2011
    367
    Are you saying you need to own a welder to be certified?
    Just For Home Projects.
    3,953
    I work with prob 100 guys that are certified and don't have a machine of any kind...Bob
    Wa
    644
    Yes, but do those certified welders go and weld on sprinkler lines with a HF 90amp welder? Doesn't add up to me...
    3,953
    Nope, you are right there...Bob
    Cave Creek Az
    1,055
    I agree with the threaded solution. Might be able to use a union an a couple of nipples (check code book for union usage for your application. Otherwise a L/R threaded coupler is available for the repair.
    Apr 2011
    367
    No, and I wouldn't think they would weld on it with the best welder on the market either...that just isn't the way to fix the problem! (The solution has already been given.)
